Engine brake 2008 Arctic Cat 366
By
dpacapt, in Arctic Cat ATV Forum
Similar Topics
By Venom
Does anyone make aftermarket engine parts for the Suzuki Quadsport LT-Z50?
Pistons, Valves, etc...?
I have found rings and complete gasket sets.... I need an oversize piston kit and valves..
One company is selling a piston, but upon further inspection it is an LT50 piston that they are saying is for the 2006 Suzuki Quadsport LT-Z50. Yet the LT50 Piston is not interchangeable with the LT-Z50 according to the pistons listed by Suzuki.
Any help would be appreciated
By JacobSlabach
hey so never ran into this before but i recently got a 04 honda rubicon 500. bought it from my doctor not running and the front brakes were locked up. cleaned the carb and it fired right up and runs great. these model atvs have drum brakes front and rear. not a fan. lost all brakes on this one when i hit some water and it got inside the rear drum case. so i ordered new shoes for the rear end no biggie. front is more complicated. has hydraulic drum brakes not sure who thought that was a good idea but the pistons in the drums rusted and locked up from it sitting with moisture in the drums.
so i had a choice to make- 1. buy new brake pistons ($120 for a set of 4) or 2. order super atv's disc brake conversion kit for $250. i HATE drum brakes so i went with the conversion kit. it said it was easy to install with no specialty tools. so i order it and turns out i have to press the studs out of my hubs to get the disc on.
anyone ever done this and if so how?
By Lellwyn Griffin
I think my rear brakes are stuck. Is these parts in the right position? Any idea how I repair? I have to give it more gas to go and I can't push it when it's in neutral.
By Micah Gafford
I've had a seriously annoying time trying to deal with the brakes on my rebuild. What size is the fitting that screws into the inverted flair cross and into the caliper? I plan on trying to make parts I need with braided steel hose.
By michaelnewell
I took front brakes apart recently and found pistons frozen in calipers. Havent been able to find cheap calipers for this bike
