May 10, 2008 ATV Obstacle Course and ATV Pull @ Sun Honda, Denver, CO
Similar Topics
By Matman
First time working with a Honda-Matic transmission. I didn't even know what I was getting into when I purchased this running beat up farm workhorse quad with black oil. I was thinking I could tear the cases apart and find the bad bearing, causing the random squealing noise when you put it into gear and give it gas. Upon opening the engine covers, I Learned about the Honda Matic automatic transmission and realized there's more than just an electronic shift motor going on in these quads. With my learning curve in major education mode, I'm now wondering two possible culprits to the squealing as I've torn the motor down and am staring at the Honda Matic transmission.
Two possible issues:
1. The bearing that is squealing is unfortunately inside the hondamatic unit hydraulic transmission which is apparently not serviceable? A new unit is $1,900 to replace it! Yikes!
2. The pull starter rope snapped and someone replaced with the wrong pull starter rope that eventually became severely worn out and the centrifugal lever/catch shows signs of wear from rubbing against the housing.
Thinking now the pull starter has nothing to do with a squealing that loud, so my attention is now on the Hondamatic unit,
Has anyone gotten inside their cases to inspect the Honda Matic transmission?
There's a only 1or 2 videos out there that are not helpful for tear down and inspection.
I understand it can't be rebuilt but wondering if anyone has looked deep enough into one to clean it out from running dirty oil? Possible identify bad parts.
I refuse to believe Honda is engineeering these as completely non-serviceable?
Thinking I will try to disassemble the Hondamatic unit m. Hopefully get into it and get all the dirty oil out and replace with fresh? Any special tools needed?
Any and all thoughts/experiences with Hondamatic units would be great conversation for me..
By Fiend_138
Anyone using the AtV/Motorcycle lift from Harbor Freight? I like the idea of having something other than jack stands. Is there another option that I should look into?
https://hftools.com/app60536
By DAFinner
Hey All,
Just wondering if anyone knows of any ATV junkyards and their contact info. I'm up in the panhandle of Idaho and we have no sources of used, secondhand or junkyards for atv or motorcycles nearby that I've been able to find. I've heard of some pretty large ones that operate east of me and would like to know if anyone here has a recommendation or experience in this matter. Thanks in advance.
By Admin
CARFAX https://www.carfax.com
By TRX300 Deer Getter
Hey all,
First time poster here. I have a '93 TRX300 with no spark. Measuring 100 volts pulsing at the coil then declining down to 90, 80, 70, 60 and so on. I assume it's the coil. If there's voltage to the coil then everything else should be in working order, right?
Thanks for your help,
Deer Getter
Similar Tagged Content
- 0 replies
- 4,568 views
- 4 replies
- 5,541 views
- 1 comment
- 2,876 views
- 11 comments
- 3,206 views
- 4 comments
- 1,957 views
Gallery Images
0
1
0
3
3By SYKOLINCOLN,
3
6By Rosko_Racing,
8
2By curtis,
5
4By patrick,
0
1
2By bansheeboy,
3
9
3
2
6
6By wylde1,
