While cruising, my 2011 750 king quad suddenly shut down. As it happened, red lights on the display flashed. Any ideas? My head lights suddenly stopped working about a week ago, if that helps. I have no power at all. Thanks
On 12/30/2020 at 6:22 AM, ScrappyD said:
Battery issue .. check terminals are tight, charging issue .. is the battery being charged ok when engine is running. Low oil issue?
I'd agree on this being my first steps as well. Check connections including any chassis ground and then check charging system. Remember it's got to be a decent bit above battery voltage when running. I remember a mention of a low oil cutoff in some reading but I might be remembering that wrongly.
Unhook battery and take it out. Make sure it's got electrolyte past the top of the plates. If not top off with distilled water. Throw on charge on it. Hook back up and see what happens.
Should be over 12v standing after charge.
With everything off while hooking up. Do you see a spark at the terminals?
If you do. You have something draining the battery when it shouldnt.
When you crank it over have a volt meter hooked up so you can see how much the voltage drops while cranking.
Shouldnt drop lower than about 9v or the battery may be shot or the improper size.
While running the battery voltage should be about 13 to 15 volts or something is wrong with battery or it's not charging while its running.
    • By mehim
    • By HoldenBoy
      Hi all,
    • By Adamb2025
    • By Asand211
      I've got a 1995 220 Bayou and the electric start does not work.  When I got it the machine was pretty rough but I was told it ran less than a year ago.  The key switch had been cut off and wires  twisted after the key was lost.  I bought a new ignition switch and repaired the wiring and it is working correctly.  It is in neutral and the neutral light is on when the key is turned on but I get nothing when pressing the start button.  I verified there is no voltage going to the starter from the solenoid.  The fuse in the solenoid is good.  Something I found that is odd is that I get positive voltage(12 volts) to the brown, black, and white wires that run into the solenoid when the key is on.  That doesn't make sense to me but I could be wrong.  I would appreciate any help I can get. Thank you in advance.
    • By davefrombc
      Anyone  carrying  a power box when  camping with their ATV?  I built  a custom  one.  I  used a  marine  battery box that  has 2  50A Anderson Grey connector  outputs (  changed one of the greys to a red), an accessory socket  and2  USB outlets,and a battery  voltmeter ..  I  added a Pure sine wave 1,000w inverter to it and A red 120A Anderson connector to the  output  posts.. To  charge the  100Ah LiFePO4 battery  I  put in the box, I added  a DC to DC charge adapter that I  made input connectors for to allow charging the battery from a vehicle's  accessory socket  or a solar panel.
      It  was a fun  project.. Besides  having a  1,000w power box for  120V ac , USB   and  12v accessories using the 10 A socket.  I  have  50  A  Anderson connectors  and the 120 A connector  to run  things like a  12v electric outboard   for fishing  trips .  The LiFePO4  battery  only allows a max output of 100A  so  it  can't be used for something like jump starting,  but  it  is half the weight and  delivers twice the capacity of a lead acid battery running accessories..  Commercial pow2er  boxes  don't  deliver  high draw 12v output to run things like  the  electric outboards.   That's one reason  I  custom  built  mine.   One box that serves for both camping and fishing.
