I've inherited a 1995 Lakota 300... it has the knob in the center of the handbar to twist to go into reverse, but I've notice when downshifting, you don't have to have the knob turned, it will shift right past neutral and into reverse which is a little dicey if not all the way stopped. I followed the linkage back and twisting the knob seems to actuate the lever on the outside of the trans, the internals just don't seem to care about this.
What is the likely problem and how back is it to get to? I've never been inside of one of these transmissions.
TIA,
-Rob
  • Admin changed the title to 1995 Lakota 300 no reverse lockout?
On 2/24/2021 at 2:04 PM, chimmike said:
Have you checked the service manual? I'm not aware of a lockout. I guess as long as it's in neutral there's no speed lockout?
By lockout, I don't mean speed lockout, but I can shift past neutral and into reverse without touching the reverse knob on the handlebar. So when your moving and downshifting, it's very easy to go too far past neutral and into reverse while still moving forward = instant wheel lockup.
crazy fix.... have you tried just taking the reverse lock lever off and testing it. My newest lakota had that issue and the lever was just installed in the wrong position. it would not allow the shaft to rotate all the way back to engage the reverse lockout.
    • By hengstserepair
      Nuetral: Runs as expected
      Lorne
    • By prdicon
      Polaris it a bit cheaper.
      Let's say 3-5 years from now.
    • By jeffrocdx
    • By sandman001
    • By wilmpie
      hi everybody
      thanx in advance
