Hey iv got a 2009 renegade 800x with no power at all no relays clicking no gages no nothing.
I look at all the obvious places and found nothing.
It was running and drove to where it currently sits and has been there for the winter.
Any advice would be greatly appreciated.
Sent from my SM-N986W using Tapatalk
Other than  repeating the obvious I can't offer  much more .
Start at the battery.  Make sure it is full  charged .Check for a blown  fuse or fusible link. Check the terminals and ground wire for  loose /  corrosion and then  follow the power forward to where it is first lost. Check   a wiring diagram to see what controls the power to that point, and so  on until you hit  on where the failure is .. There are service manuals for earlier Renegade 800 models in the downloads section that  may have the same wiring diagram  as your machine.
Never thought of looking for a manual I'll have to try and find one.
I did just figure it out there was a short on the kill switch so even with the switch off the machine thought the kill switch was on.
I uploaded the wiring diagram if you need it:
    • By Adamb2025
    • By Callaway
    • By BillR94
    • By WeeBee
    • By davefrombc
      Anyone  carrying  a power box when  camping with their ATV?  I built  a custom  one.  I  used a  marine  battery box that  has 2  50A Anderson Grey connector  outputs (  changed one of the greys to a red), an accessory socket  and2  USB outlets,and a battery  voltmeter ..  I  added a Pure sine wave 1,000w inverter to it and A red 120A Anderson connector to the  output  posts.. To  charge the  100Ah LiFePO4 battery  I  put in the box, I added  a DC to DC charge adapter that I  made input connectors for to allow charging the battery from a vehicle's  accessory socket  or a solar panel.
      It  was a fun  project.. Besides  having a  1,000w power box for  120V ac , USB   and  12v accessories using the 10 A socket.  I  have  50  A  Anderson connectors  and the 120 A connector  to run  things like a  12v electric outboard   for fishing  trips .  The LiFePO4  battery  only allows a max output of 100A  so  it  can't be used for something like jump starting,  but  it  is half the weight and  delivers twice the capacity of a lead acid battery running accessories..  Commercial pow2er  boxes  don't  deliver  high draw 12v output to run things like  the  electric outboards.   That's one reason  I  custom  built  mine.   One box that serves for both camping and fishing.
