So my prairie 360 4x4 won’t run right out a new carb on and it would drive fast for like 2 mins and after that if you try to give it to much gas it just pops and won’t let it rev high
I have a 2005 Kawasaki prairie 360 and I added a new carb but when you go and give it gas afte like 1/4 throttle it will just pop and sputter won’t rev very high. When I first put carb on it would go good fast as you wanted for like 2 minutes then when I slowed down it just started it’s sputtering and popping and has done it ever since guy I got it from said it just had motor work. But others are saying they think it’s the motor
  • 9 months later...
My Prairie is doing the same thing. I have used around the farm for basic tasks but I need it to go hunting now and I want to fix it. Have you tried putting the old carb back on?
    • By BillR94
      Thank you for your time
      Bill
    • By joezee13
    • By middlebrookgt
    • By HighPlainsIT
      My son's trying to get a 2003 Prairie 360 running. Over a year ago, he'd rebuilt the carburetor using a SHINDY 03-112 rebuild kit from JT Cycle & ATV, and it was working fine; however, when it wouldn't run recently, he took the carb apart and the jet needle was rusted in place. He cleaned that up as good as possible and replaced the jet needle with the old one that wasn't rusty. Now, he can only get it to start about 1 out of 5 tries, and when it does start, it won't run unless the choke's on. The spark plug's good and is sparking. It has compression. Any ideas on what he should try next or look into?
