I got this 660 a couple days ago. Apparantley, and older gentleman bought in new in 02, rode it a few times and parked it. It has 500 miles and 50 hours on it. So, a dude bought it cheap, and though he could get it running just by cleaning the carb, tank etc. Well, that was done, and it still doesn't start. So, I got it from the 2 nd owner thinking I can fix it. I started checking it out, cleaned the carb (the 2nd owner let it sit for some time too) and when I crank it, it sounds like it wants to start, it might even do a little backfire but no go. It's got spark, I changed the plug, however, the compression came in at only about 25-30 psi. Damn. So, I checked the valves and the intakes R and L seemed just a smidge tight. The middle intake, tho, had a big gap that I could see with the naked eye. So, I'm wondering if somehow that valve hit the piston and bent it?
So. thinking about this thing overnight. The cam chain is intact and the tensioner seems to be working properly. The original owner let the thing sit for about 15 years under a tarp. I was mistaken about the guy that I got it from. He did get it running for a short time, and it crapped out and he didn't figure out what was wrong with it. I'm wondering if the center intake valve stuck and got hit by the piston. I'm going to get a leak down tester today and see what the deal is.
      Best ATV for Older Riders
      Polaris Sportsman 570 EPS
      Best Reliable ATV for Seniors
      Honda FourTrax Rancher EPS
      Best Features
      Best Premium Comfort ATV
      Can-Am Outlander MAX
      Standout Comfort Features
      Best ATV for Easy Handling
      Suzuki KingQuad 500AXi
      Why Older Riders Like It
      Yamaha Grizzly 700 EPS
      Best Features
      Arctic Cat Alterra 600 TRV
      Key Advantages
      Electric Power Steering (EPS)
      Automatic Transmission
      Lower Seat Height
      Two-Up Models
      Hand Warmers and Heated Grips
      Adjustable Suspension
      Buying Too Much Power
      Ignoring EPS
      Choosing Aggressive Tires
      For most mature riders:
      Final Thoughts
    • By PupATV
      Hey guys! I am new here to the forum and need some help getting my Polaris 325 Magnum 2001 Running.....So I got it for free and it has never run quite right...I put a aftermarket carb on it last year and it was running fine but it only went like 20 maybe 25mph max......But then the needle and seat sealed leaked within a yeah and it flooded it REALLY bad so I changed the oil because it was full of gas. So then I put a genuine Polaris carb on it and I have it set to all the factory specs, but it was still not running right....So I replaced the ignition coil and the spark plug and that solved one of the problems I had (It would bog down and stop running when i would go up a hill) But it still didn't have that much "Punch" to it like my Kawasaki Prairie 300 ans Suzuki Kingkuad 300.....So I replaced the CDI but it's still not running right! It's acting like it rich kinda....So it runs mostly okayish when I have the airfilter on but the top of the airbox off but as soon as I put the airbox lid on it like REALLY bogs down and wants to stall really bad. I have the carb at the factory specs and it has a pretty new fuel pump so I have no ideas whats going wrong! It still nly has a top speed of only about 30-35mph and it sounds like it's choking the whole time! Thank you for sticking to the end, and I hope you guys can help me!
      -PupATV
    • By sunn
      I have an older 2000 Honda 450 ES which has been a tremendous workhorse since owning it new.  I'm now looking to update neglected maintenance on the machine, looking for advice initially on brake work?
    • By bhristianzx12
      I have acquired a free 92 Polaris 350L 4X4. Ive replaced carburetor from ebay, replaced spark plug, im trying to pull start but sounds like it doesnt want to fire. Spark is a bright orange spark (checked with spark plug tester), replaced plug, pre mixed gas from an external gravity feed tank. Compression test good. Anyone got any recommendations for me?
