2005 Honda Fourtrax 400es
By rjsummer
I have a 2015 Outlander L 500 max.
any way to change the start up message in the cluster WITHOUT taking it to the dealer and paying $100???
By vlxerdon
Hello from southeast Georgia. Was gifted a 2000 Yamaha bear tracker with out a carb or battery and looking like it had seen better days. Was told it had sat for about three years. Explained a lot. Put a carb on and a battery in and it started right up. Surprised the heck out of me Anyhow as stated in my opening I am 78 years old with a very long motorcycle backgground but brand new to atv's. Anyone else out here from Georgia? Would like to meet up with some folks for a ride or two. Looks like a great site. Thanks for having me.
Don
By joezee13
After turning off engine in neutral starter wont engage If I rock unit back and forth it engages Getting progressive worse.
By middlebrookgt
Hi All. I introduced myself some weeks ago with my 2006 LT-F400F that needed a list of repairs including replacing the cracked generator cover. It is back together as of last night and cranks up, idles and revs high pretty well. Needs some fine tuning and stop backfiring at stop.
The big issue is it will not go into gear. I reassembled the insides with help from y’all’s posts. The transfer selector moves from H-L-R, and the foot shifter moves thru the gears and finds neutral easily enough. Before I tear it back open, the transfer selector on top does not move as far as the repair manual says. The diagram shows the shaft moving something like 40 degrees between L and H and 50+ degrees between L and R but it doesn’t move that far even though it finds the indent areas and moves well.
Could this be the problem. I aligned all the dots on the shifter gears inside and it appeared to not be binding anywhere. I do hear the gears touching when I shift like they are trying to engage, but zero movement from the ARV
Are there better/bigger photos somewhere that would allow me to be confident I included all the washers and bushings, etc? If I had any doubt on parts that were laying inside after the cover broke then I purchased replacements from online stores.
TIA for any input or feedback!! Pics are from when I first took the generator cover off.
