Hi, I have an apollo blazer 125 cc with a issue that stator that gets extremly hot.   I replaced the original, then the new one got so hot one wire in the stator melted the solder joint. bought one more and this one also gets hot.  I tested the stator wires and I have continuity to ground.  I think the heat ruined it? or was that my issue.  what can I check to figure out why my stators are going bad.   I did check for continuity between wires to the cdi and reg and they seem fine.  although all the wires seem thin (cheap chinese atvs) i din't find a smoking gun with wire showing high impedence. any advice would be greatly appreaciated.
  • Admin changed the title to 2020 Apollo Blazer 125cc stator hot
    • By Dsluder
    • By Jdeaton011989
    • By gordonmacritchie
      all fuses are fine
      any ideas how to correct
    • By digrig
      Hey everyone,
