Hi all, working on a KQ for a friend, while he was out of town his little brother decided to take the entire thing apart. Unplugged every connection, took out the engine, then couldn't get it back together. It's a mess. I have it to the point that the fuel pump primes when the key is on, it will crank but has no spark. The display is blinking a temp light and an Fl light. I'm getting mixed information about what the Fl  means.  Also coming off the wire harness next to the ignition coil is a wire set with one orange with black stripe and one black with white stripe wire. I can't figure out where that is supposed to connect. Any help would be great.
    • By HoldenBoy
      Hi all,
    • By digrig
      Hey everyone,
    • By Asand211
      I've got a 1995 220 Bayou and the electric start does not work.  When I got it the machine was pretty rough but I was told it ran less than a year ago.  The key switch had been cut off and wires  twisted after the key was lost.  I bought a new ignition switch and repaired the wiring and it is working correctly.  It is in neutral and the neutral light is on when the key is turned on but I get nothing when pressing the start button.  I verified there is no voltage going to the starter from the solenoid.  The fuse in the solenoid is good.  Something I found that is odd is that I get positive voltage(12 volts) to the brown, black, and white wires that run into the solenoid when the key is on.  That doesn't make sense to me but I could be wrong.  I would appreciate any help I can get. Thank you in advance.
    • By Ironworker709
      I have Grizzly 700 that has been pretty much totaled out in a bad accident, but it will still run and drive good...
      Will this engine swap into any of the Yamaha UTV's like thr rhino and Viking 700's?
      Was just going to sell it as is for a engine for someone who needs one pretty cheap..but been thinking about getting a UTV for the family and maybe find one with a blown engine cheap and swap it out
      I already an excellent shape 2001 Big Bear 400 4x4 for us..but kinda been looking for a good used UTV for us and the grandkids on our property to play with
      Not sure of the year..i can't remember what year it was when i picked it up for a buddy a few years ago..he went to jail after he totaled this thing and told me to pick up a few things at his house he was renting and just keep them for myself since he owed me a bunch of money before the landlord sent them to the dump...
      The first picture is when i went and picked it up for him..second is how it is now..frame is all twisted up and plastics are fubarred..going to sell the rims and tires.they stick out way too wide on my Big Bear
    • By shorty
      FYI: I used a volt meter to test the stator/rotor output. Pulled the plug on the rectifier/regulator to access the 3 wires coming from the stator. The other 2 wires are 12v pos and negative so easy to identify the 3 stator wires, which are yellow on my Kowhockey. You should see around 30v AC not DC coming from the engine stator. Test all three wires to EACH OTHER not ground. Remember the stator puts out AC like an alternator. The rectifier converts the AC into DC to charge the battery. On my case the rectifier/regulator was bad, obvious because the 3 stator wires showed 30v AC
