FYI: I used a volt meter to test the stator/rotor output. Pulled the plug on the rectifier/regulator to access the 3 wires coming from the stator. The other 2 wires are 12v pos and negative so easy to identify the 3 stator wires, which are yellow on my Kowhockey. You should see around 30v AC not DC coming from the engine stator. Test all three wires to EACH OTHER not ground. Remember the stator puts out AC like an alternator. The rectifier converts the AC into DC to charge the battery. On my case the rectifier/regulator was bad, obvious because the 3 stator wires showed 30v AC
  • Thanks 1
    • By oztrax
      MAX 4 6X6 2008
    • By prdicon
      Polaris it a bit cheaper.
      Let's say 3-5 years from now.
    • By Rockbottom
      any ideas how to correct
      thanks ahead
    • By middlebrookgt
    • By smallmotor2002
      Hello everyone.
      I'm working on a 2014 Yamaha 700 Grizzly and having no luck accessing the diagnostic mode on the display. I have tried with the fuel pump connector plugged and unplugged, and select and reset buttons depressed simultaneously for up to 30 seconds with no luck.
      I could sure use some assistance if anyone has any tips on this
