96? 350 big bear select gear issue
By rjsummer
By jen
Cannot find out why 12 vdc 4 (4) commutator starter motor has no power. It will run full speed without load. But with any load will not turn. Repaired broken brush holder and insulated an internal wire to magnet that was bare and rubbing. cleaned commutator segments. Ohm readings while slowly rotating commutator was 1 ohm. When attempting to run with load it will not turn and Bat vdc only pulls down to12vdc. Cannot find an internal wiring schematic. I can buy a rebuild kit ~$35 but WTH?
By middlebrookgt
By Ejwill
I rebuilt the top end on my 2007 Honda Trx500fe. It ran fine right after the rebuilt. But now when I try to crank it it blows Bach through the carburetor. I held my hand over the opening for the intake air and it blew gas back on my hand. Can figure out what happened all of a sudden. It was cranking and was able to ride it running through all the gears. Now can get it to crank just blowing gas back to the air filter. Need help again. Starting to think I should have walked away from this one.
By JustCrazyNoQuadNeeded
'Gidday. An issue I can't find discussed already - my Bear Tracker selects into 1st gear fine. Selects other forward gears fine too but all above 1st gear are slipping. Can select reverse but nothing engages/happens.
Any ideas what I might be dealing with?
Cheers, Jim.
