So I bought three older quads for the farm and the two Suzukis (1986 and 1996) both smoke (oil) quite a bit on start-up, while the other (Yamaha) doesn't.  It isn't a big deal except that I start them in a garage and it gets a bit smokey and smelly!
Is this a common Suzuki thing or did I just get lucky??
If it's a common issue, is there an easy fix?  (For the record, they both run good, and both clear up as soon as they get a bit warm).
The smoke at startup will probably be the valve guides leaking oil. It runs down the valve stem. The valve keepers/spring retainer plates aren't meant to, but they act like funnels to drain oil down the valve stem while it's sitting over night. There are seals on the valve stem to stop that, which are probably worn, and it might also have too much play between the valve stem and the valve guide, but, if it runs without smoke once it's warm, (and you really want to look for smoke as you put the throttle on at the bottom of a hill to check there is no smoke then), then it will probably come right with just new seals. I think they might also have an O ring under/on the valve guide where it fit's into the head, but they seldom play up. The top ends of those things have a pile of oil up there when you take the valve adjuster caps off, especially the exhaust one, but that is normal and doesn't normally matter as long as the seals are ok.
You are likely correct though it seems to last longer than I would expect from bad valve guides.
I doubt there is much to do anyways as if it is valve guides or piston rings or whatever, I will likely have to learn to live with it.
I was more curious if this was a common thing with Suzuki quads.
The suzukis hold a lot of oil up in the valve case. It could leak a lot of oil down the guides. Given the circumstances you describe, I doubt it's the rings.
Oil's cheap..ish.. cheaper than getting your motor worked on by a shop.
And no I don't think a smoking suzuki is a common thing..  I've had lots through my workshop and started them cold and I don't remember ever seeing one smoke bad at cold start.
      Heres my story. Kinda long. I guess I was a late bloomer when it comes to quads. I had never ridden a quad in my life. Rode Dirt Bikes as a kid growing up. Back in Oct of '06 I found a Mustang on craigslist. Took it for a test drive one morning before work. Fast car. 351 Cleveland. I had planned on meeting the guy again after work. For some strange reason thats still to this day beyond me, I stopped in Hillsboro MotoSports on the way home from work. I had 6 Grand on me. There was a left over '05 sitting by the front door. It was on sale for $4999. It was $5499 OTD. I didnt even look at anything else. I knew nothing about quads accept I thought it really looked coool and I had the money in my pocket to buy it. I was sitting on it when the salesman walked up and asked... "Can I help you?" Without hestitation I pulled 60 Ben Franklins outta my front pocket and said "I want this Quad. Load it up in my truck." It was just about dark by the time I drove away from the shop. BTW, I didnt bother to ask my ol lady if I could buy it. LOL. Anyway, I took it by the house and showed her. She was kinda stunned but not mad. We drove over to a friend of mines house and unloaded it. I took it to the field across the street from his house. HOLY CHIT!!!!! I was surprised by the power. I had it for about 2 weeks and took it to Sand Lake. I was there a few hours and rolled it on a banked turn at the top of the bowl right before you get to the one-ways. When it rolled, I flew off and landed on my belly. The quad came bouncing and landed on my back. For a month I couldnt even walk. I was scared of it. I considered trading it for a 250EX. Went back to the shop. The salesman said..."Dude!!! You dont want a 250EX!!! Trust me. Just get used to it" I still wasnt convinced. I put it on craigslist for $4000. Calls were coming in. I had a guy that wanted to come look at it that evening. I decided to take it for one last ride at Browns Camp before I sold it. I was still afraid of it. After about 5 minutes I started feeling comfortable on it again. I decided right then, I loved my Honda 450 and would learn how to ride it instead of selling it. That was late Nov of '06. Work was slow for a Painter in Oregon. My new job everyday? Going to Browns Camp and ridding my Quad. I bought my Girl Friend an '02 Blaster. I rode my 450 for 4-6 hours almost every single day for 3 months. And yes, I know my way around Browns Camp pretty well. LOL. In March I bought her an '06 TRX250EX (Thank God I didnt trade my 450 for one of those) LOL Since then, I have become totally addicted to quads. I love them. Couldnt imagine not owning at least one quad. Luckily I have two. My "07 was $6500 OTD in July of '07. Bought it for my Girlfriend. Traded in her 250 EX. A month later we broke up. So, I wound up with two Honda 450's.
    • By Tinkeringreg
    • By Mhatayas
