1986 Honda trx250 three wheeler conversion
By TomJulio
I recently noticed my Fourtrax 2WD has 4WD wheels installed on the front. The back spacing is significantly different than 2WD wheels and they are almost touching the strut springs and the tires actually do touch the springs.. So far, no luck locating 2WD wheels to correct this issue.
By Olchap
Thank you,
Olchap
By BuckBilly
Just thought I would start a poll on this topic manly because I'm not a fan of belt drives. Just want to know which you prefer.
By C2INS
Does anyone know if they're interchangeable? I have a 2002 TRX20TE and 2007 TRX250TE, so getting to a set of common engine parts would be ideal.
