The VIN's on these era Polaris' are only 7 digits. They went to a full VIN around 1998 from what I recall.
You can look up the VIN you have and identify the year make and model. I had a Blue 1995 Polaris 300 2x4 VIN 2563837 and the VIN record showed it was a 1995 Polaris 450 4x4 with a generic picture of a green 4x4.
The summary was that the VIN couldn't be used to order parts, only the make, model and displacement info. The motor Serial number didn't help either.
With a 7-digit VIN, there just isn't enough characters to identify much about the vehicle. You can't include many details other than mfg, year model.
As a matter of fact, just getting it Titled and registered was overkill because the VIN didn't clearly identify the year, make and model.
  • 4 months later...
    • By noticon75
    • By LashinWheeler
      Any help would be great,
      Thanks!
    • By cruteg8
    • By Shorty51
