  • Ajmboy changed the title to 1987 Suzuki Quadsport 230s TDC
  • 7 months later...
I am almost a year late on this, but I know on the 230s with the kick start, you can take the stator case off and line up the notches on the stator, it will have you at TDC.  My son literally did it today.
    • By Damien911
      Setting the timing on a 2005 Yamaha 250 Bruin
    • By Thebritish
      My bayou 250 came to a stop and would not not start, it turned out the starter clutch had a fit and died. I changed the starter clutch which had sheared off the 3 bolts attaching it to the flywheel and everything went smoothly. However, when I went to start it I found it would not start. On investigation I found the timing out of whack, by alot. Thinking it was something I did on the repair, I repeated the process of removing and reinstalling the starter clutch and related components and resetting the engine to TDC. Tried to start and immediately realized the timing was out of sync again.
      Is there something I'm missing? Could there have been a bigger issue, possibly on the other side of the engine? I don't understand why, with a brand new starter clutch there would be such movement in the crank. The timing chain and sprockets do not look worn and appears to be tight on the tensioner. When I move by hand everything appears to move as you would expect. But when I try to start it using the starter or the pull start it goes out of whack!
    • By anthonyd256
      I have a 99 Yamaha bear tracker and I have converted the front brakes from drum to disc fairly easy but I cant figure out how to convert the rear with out hacking apart the rear arm. tried to use parts from a wolverine since the rear arms look similar but the caliper mount didn't line up on the bear tracker axle. Can anyone give me any clues or has anyone successfully converted the bear tracker rear brakes. I would even purchase a conversion kit if there is one. Any help on this would be greatly appreciated.
    • By p5200
      I'm having trouble identifying Mark. I know where the mark is in the Stator cover. Is the T at about, the 12 o'clock position in this photo? I've got to buy another Stator cover as the one I have has a hole at the bottom of it. Due to failing eyes, I have a lot of trouble anymore. Thanks! 🙂
