Transforming my ATV
Similar Topics
By skeeter45
Guys, having trouble finding the correct rubber boot for my big Bear. I've ordered 2 of them and both are wrong. The old one was 4 inches across on the end with the tabs. New ones are 5 inches across. Much to big to fit properly. TIA Hope someone has an idea. -
By bubblegumshrimp
After 25 years of driving nothing bigger than my current 570 x2, I have a 22 XP1000 Hunter Edition on its way. Super excited about it. Any tips from fellow riders for someone new to the liter?
By QuadRunner
I'm hoping someone can help me diagnose my 2008 King Quad 450 no start
A couple days ago, after running for a few hours at low speeds (2-3mph wiping weeds), seat got hot, motor started to stumble, and we turned it off. Gave it a few minutes to cool down, turned on key, dash flickered, then lit up, I tried to start, but it did not turn over, dash died like the battery was dead.
Quad acted like it was overheated, but I noticed a lot of heat coming from battery area. Checked battery voltage, showing 10.5 volts.
I had something similar happen last year, and it ended up being the regulator/rectifier. It killed the battery that time too.
So, this time I pulled the battery, it stayed quite warm for over an hour. Put it on trickle overnight. Next day it showed over 12 volts. Took it to advance auto and had it tested. Bad cell. Bought new battery.
Installed new battery. Now when trying to start, it seems normal, turns over, and begins to start, but immediately dies.
I have ordered a new regulator/rectifier that will get here tomorrow. But today, I pulled the regulator and tested it according to the service manual. Ran a diode test using my multi-meter between all the pins on the regulator. They were all within range according to the service manual.
Unplugged stator, and tested it. Showing 1.9 ohms between all pins. This is out of range. Should be .1-1.0 according to manual. However, I have a brand new spare stator, and that one also reads 1.9 ohms. I'm guessing my multi-meter is the problem?
Used a paper clip to jump pins and put the dash into "dealer mode". Shows C00. No codes.
Last time the regulator failed, I was able to remove the negative battery cable and do a leak test with the multi-meter. I observed a voltage leak, and when I unplugged the regulator, it would stop leaking. This made it clear to me that the regulator was the problem. This time, no voltage leak. Also, last time the regulator failed, it would still run fine with a new battery, it just wouldn't charge. Now it won't stay running for more than a second. I'm thinking this could be something else. Any ideas?
By oxidized_black
1999 - 2004 Can-Am All Line service manual
http://rapidshare.com/files/4269188252/1999%20-%202004%20Can-Am%20All%20Line%20Service%20Manual.zip
2003 Can-Am Rally 200 service manual
http://rapidshare.com/files/1466175272/2003%20Can-Am%20Rally%20200%20Service%20Manual.zip
2006 Can-Am Bombardier Outlander Series 400 & 800 Shop Manual
http://rapidshare.com/files/1526634762/2006%20Can-Am%20%20Bombardier%20Outlander%20Series%20400%20%26%20800%20Shop%20Manual.pdf
2006 Can-Am 400 & 800 Outlander service manual
http://rapidshare.com/files/906874897/2006%20Can-Am%20400%20%26%20800%20Outlander%20Service%20Manual.pdf
2006 Can-Am 400 ATV Motor Shop Manual
http://rapidshare.com/files/1087506035/2006%20Can-Am%20400%20ATV%20Motor%20Shop%20Manual.pdf
2006 Can-Am 800 ATV Motor Shop Manual
http://rapidshare.com/files/3209628612/2006%20Can-Am%20800%20ATV%20Motor%20Shop%20Manual.pdf
2007 - 2008 Can-Am Renegade 500 & 800 / Outlander 500-650-800 service manual
http://rapidshare.com/files/2295042057/2007%20-%202008%20Can-Am%20Renegade%20500-800~Outlander%20500-650-800%20Service%20Manual.pdf
2008 Can-Am DS450 Shop Manual
http://rapidshare.com/files/938708221/2008%20Can-Am%20DS450%20Shop%20Manual.pdf
DS450X Specs
http://rapidshare.com/files/1642152510/DS450X%20Specs.pdf
By Admin
View File 1982-83 Honda ATC 200E Big Red Shop Manual
Submitter Admin Submitted 07/24/2022 Category Honda ATV
Gallery Images
0By VasMas,
1
4By iball511,
10
5By RockCandyChris,
2
0
9By tnfoxracer,
3By curtis,
4By Jrod,
1By banshee1,
3
4By globob24,
0
9By oxidized_black,
3By mjl01,
7
0
6By Chazman,
3
