92 moto4 shifting issues
Go to solution Solved by Mech,
just picked up a 92 grey moto4 350 runs great, but has major shifting issues, I believe it shifts into 3rd gear and 5th gear, but if you shift all the way to 5th gear first then back down to first then first gear might work but then nothing for second then 3rd will catch.
So do you feel this is a clutch issue or is the trans pretty much shot, I figured if I have to tear into the trans then just rebuild the motor this winter, but if it's just clutch parts repair it now and have fun with it.
Thank you for any reply
Drain the oil and use a magnet to find bit's of metal.. Flakes, chunks, dust..
It might be blown gears, but it might be something simpler, in the gearchange linkages.. inside the side case if you were lucky, rather than deep inside..haha.
ok took it all apart split the case and guess what issues I found...... nothing everything looks good I even bought used transmission parts
to replace any broken parts.
Now the question before I put it back together is there a certain place the gears should be? Or do i put it back together and after everything is back on It will know
what gear it should be in (I can't really explain what I want to say).
Last thing I can't seem to find a case gasket for it so what do you use for the cases?
  • Solution
The workshop manual will tell you exactly where and which way each gear should be on it's shaft, with spacers etc, and which shift fork goes where.
The cases don't have a gasket, just sealer, and I'd highly recommend you buy a tube of loctite master gasket and use.. It's clean to use and doesn't leave long strands of squeezed out silicon inside the engine to block the filters..  It doesn't really matter what gear it's in as you assemble the cases(if that was the question).
As for the gear shift, I'd put the center cases together temporarily and try every gear change by turning the shift barrel from in the side case, whilst turning the two gear shafts. It would be good to have the lever and wheel in the side case that rubs on the shift barrel and holds it in each gear. That wheel both holds it in a gear once selected, but also makes sure the shift travels all the way into gear if you don't move the shift lever full travel. The shift barrel may be a little tight to turn if it's all dry in there, but you should be able to turn it with your fingers as long as you turn the shafts enough. Sometimes you will need to turn the shafts quite a few turns to allow the cogs to line up and engage, but they should all slip nicely from one gear to the next with enough turning of one or both shafts. Be patient, test it carefully up and down through all the gears.
If you can get all the gears at that point, it suggests the problem is in the outer/side case, something in the shift mechanism before it gets to the shift barrel. Possibly the return spring on the lever, or the spring on the ratchet mechanism, or the ratchet mechanism itself.
Post photos if it's easier than trying to describe things, or, get the manual or look things up in an online parts place, and describe parts as the book does.
    • By Joeguy
    • By Cj Winds
    • By KIWINZ
      Hello
      My son scored a free Moto4 - late 80s from the looks of it. I don't know anything else about its history as the owner wasn't there when i picked it up. Can't see the VIN number as its a bit rusty.  He cleaned the carb and then with some either it started and still starts first pull.  Its runs really nice - not rattles etc.  Goes forwards well and the brakes work fine so it looks like a keeper, However, we have only managed to get it into reverse once.
      1) it won't shift down into what seems like where first would be - 2nd and upwards only. The changes between gears is fine.  No crunching or missed gears - just no first gear.  2nd gears appears to be as low as it will go
      2) the clutch - when you hold the gear lever up or down works (only the second ATV we have had.  Other is a Quadrunner which doesn't have this feature)
      3) no neutral light - will start when no in neutral - should it do that?
      4) the one time we did get it into reverse the neutral and then the red (reverse) lights worked. Swapped easy between forward and reverse - when it went into second, it didn't return to first or neutral
      5) checked the clutch adjust on the RHS - seemed fine to me.  When i turned the screw back 1/8 it was where it was to start with.  Clutch doesn't slip.  The bike will move forward is all gears.
      Any help would be appreciated
      Andrew
    • By Ant-Knee
      I am trying to rebuild an engine for a '97 Kawasaki Prairie that I recently picked up. There is one head bold that just won't let go. Nothing I do seems to make a difference. I have been putting penetrating lube on it for two days straight and I am afraid it is going to break on me. What is your best advice for getting the sucker out? I have tried a rechargeable impact, a pneumatic impact and penetrating lube.
