Thanks.  I tried that already but you can't download anything until you've made 10 posts.
1 hour ago, Mech said:
I'd say take that big nut off and the axle will slide to the right..
Or there's another big nut on the other side under the brake drum, then it slides left..
Thanks.  That's what I have been thinking.  The bracket for the sprocket won't move so I'm thinking I will have to pull the axle out to the left.
Thanks for the diagram.  I will save that.
    • By WeeBee
    • By kingkw
      I have a Harbor Freight tire changer. I could not get the tires off the rim.
    • By BillR94
    • Guest Fox300exchic
      By Guest Fox300exchic
      Here's mine...
