Have you read the service manual ? Is the dash flashing ? Have you tried getting the trouble codes out of the dash ?
Are you sure the new battery is good, and fully charged ? Have you checked the charging is charging, and regulating ? Are you sure you didn't momentarily connect the battery up backwards, or try to jump start it but connect the jumpers backwards momentarily ?
When you say it won't shift gears in forwards, do you mean it moves but only in one gear, or that it won't go into any forwards gears ? Just to clarify before I start looking in the books.
And in reverse, it moves ? but the engine runs badly or just has no power ? If the motor is running ok, but has no power in reverse it might be a gearbox/control problem, or it might be an engine problem..
Edited by Mech
  • 5 months later...
Bummer when someone posts a question and members take the time to reply and the OP never shows up again.
Thanks @Mech for posting so much on the forums and helping others out. I am new here but looking forward to peruse the forums here and there and learn how to better service my own ATV from other people's problems and solutions and perhaps with time and more experience contribute back.
    • By hengstserepair
      Nuetral: Runs as expected
      Lorne
    • By jeffrocdx
    • By sandman001
      any ideas how to correct
