Okay, so I have a 2002 Rubicon 500…bought it last year and it sat for several months until I put a new rear axle in, FINALLY got that done and was super excited to finally have my wheeler going, just to notice a strong gas odor. Popped the seat off and sure enough, pouring gas from the carb overflow. Fast forward a few more weeks and get the new carb and get it in, no leak! Yay. Except now I have no spark. 😒 I’ve tried another plug and checked and am getting no power to the coil pack. I’ve read and read and mostly what I’ve found is ECU, which is fine…but I like to exhaust all avenues before buying the more expensive parts just because I don’t wanna spend the money and it have ended up being something simple that I overlooked because I was trying to rush. 😂 I don’t know if it’s relevant, but I read on another post that someone had similar issues with theirs and it was the sensor on the side of the carb, just a thought since this literally happened after I put the new carb on. It also displays “- -“ on the display screen where it should show the gear position.
  • Ajmboy changed the title to 2002 Honda Rubicon No spark, “- -“ on display screen instead of gear position.
Suspicious only happened when you changed the carb, there is a throttle sensor on the carb, you might check that for proper function, also a lot of wires in that area you might check to make sure nothing got unplugged. Those carbs are fairly high tech and a new one may not be talking correctly with the ECU, depending on whether its OEM or aftermarket.
  • Thanks 1
On 1/12/2023 at 8:29 PM, Mech said:
The manual says it will set a code if the throttle cable's been disconnected..  You need to refer to the manual HPorter..
Thats high tech for 2002
    • By oxidized_black
      Engine
      Chassis
      Size
      Basics
      Features
    • By JMSwed
      Hi EVERYONE
      New member here
    • By Chucksta
      So.. It has now become cranky about changing from "drive" to "reverse". Sometimes it's seamless as it's always been, other times it just goes "click, click....click, click " when going from reverse to forward, or from forward to reverse..  Then it gives up and just stops at neutral.  Only thing that seems to help is to give it a bit of a bump / wiggle with my own weight. Any ideas as to what to check? It's low miules / hours .. Dealership maintained..
