Like many things on this machine , pull starter is not working , recoil spring is missing , didn’t saw this when buying.
Today afternoon I will get grounds wire’s check.
If you jack the back end up Kuba, put it in third or forth gear, then reach under one back wheel and pull it backwards hard, it will spin the motor over..  like a pull start. You could check the spark like that, and start it if it was going to go..
    • By cavry
      Cavry
      Topics covered include:
      Polaris RZR 570 engine repair
      Brake system repair
      Popular related searches:
      Polaris RZR 570 repair manual
      RZR 570 wiring diagram
      Polaris RZR torque specs
      RZR 570 clutch problems
      AWD and differential repair
      Brake system service
      Sportsman 570 wiring diagram
      Sportsman 1000 wiring diagram
