Like many things on this machine , pull starter is not working , recoil spring is missing , didn’t saw this when buying.
Today afternoon I will get grounds wire’s check.
If you jack the back end up Kuba, put it in third or forth gear, then reach under one back wheel and pull it backwards hard, it will spin the motor over..  like a pull start. You could check the spark like that, and start it if it was going to go..
    • By wanrep
    • By wanrep
      YFZ05YYXH
      YF05RH
    • By RadRob
    • By leecon
