Hi.  I am looking to purchase an ATV for a Bahamian island called Bimini.  It is 50 miles from Miami.     I am looking for something that will ride the beaches without getting stuck.   There is lots of shoreline with some mangroves, vegetation.   So will probably need 4x4 for that area.  But I ready somewhere that the  the extra weight of the 4x4 in the front of an ATV will weigh down traveling on teh beach and make it more susceptible to getting stuck?      I would think you'd want 4x4 for beach sand.    I would also like to use this ATV to pull a small trailer for bringing trash to the local dump.     I am considering the Honda 420 4x4 with foot shift (dont want to fix ES on an Island).  I am also considering the Honda Foreman for the pulling capacity but I'm concerned that the extra weight of the Foreman will be prone to getting stuck in beach sand.   Anyone have an opinion?
Edited by BiminiMike
Hi. I'm in New Zealand and we have plenty of beach sand and some truly huge sand dunes here. In beach sand two wheel drive quads do just fine, even up the dunes that have drop-offs, and, as you suggest, the slightly lighter weight does allow them to skim over the top. In the dunes two wheel drive is nicer, lighter, more nimble and fun. I've also driven two wheeled bikes (XR hondas) though in mangroves, with mud up to your nuts, and I think you really would be better off with four wheel drive there. In the soft beach sand having four wheel drive is no disadvantage, they still go everywhere, but they feel heavy and do sink in slightly, but the four wheel drive hauls them through regardless.
If you are going to be going into deep mud I'd recommend the four wheel drive, and yeah, hondas are excellent and the bike that's favored by our beach dwelling crowds.
I think the foreman would be an excellent choice, 4 wheel drive is great, but they are harder to steer , so I would get the power steering model. You may or may not need sand tires it really depends on the sand.
    • By mehim
    • By logray
      Hi all,
    • By geezer99
      Well, I bought the Axis 500 sold at Lowes for $8999 a couple days ago.  This post will be about my impressions as I use, fix, and abuse the machine.  I will add to the post as I gain experience with it.
      Thanks to other posters on this site warning of new machines with loose hardware, one of my first actions was to crawl all over it checking fluids and connections.  Zirks were all freshly greased, fluids in engine, and gear boxes were up to level.  One of the little gas struts that help lift the bed to dump was dangling with only one end connected, and the other strut had not been fully tightened.
      The rear gearbox does not have a differential in it.  It is essentially a solid axle.  Tight turns on lawn will leave tracks, and turns are not as tight on pavement.  In my case this won't matter much, but if you plan to use it on a lawn, this will create tracks on turns.
      To check engine oil you need to remove both front seats and a plastic cover.  This according to the manual.  I'm pretty sure it can be checked with that stuff in place, either from under or above, but that remains to be seen.
      I am not used to a CVT transmission.  I am used to a clutch and multiple gears.  This one requires giving it plenty of gas out of the hole and then backing off to get it to shift up.  I'm sure I will get used to it, but I'd like to be able to take off quietly if I want to.
      The doors have bungie cords to act as springs to close them.  I removed the driver door so I would not need to fight the constant pressure to close.  Problem solved.  I will leave the passenger door as is.  Gotta keep the grandkids safe.
      Here is some stuff I like:
      I was concerned about there being enough torque to slowly climb a steep hill.  There is.  I will elaborate more on this when I've had it on my steeper trails.
      The display has dedicated lights to indicate status of gear position, low oil pressure, over temp, and a bunch of other stuff.  This helps a beginner with feedback that an action taken was successful.
      The sparsity of knobs on the tires dig in well on most surfaces.  I bet they wear out fast on pavement.
      The tilt bed has a tail gate that is easy to operate.  Much like early Japan pickups.
      Steering is responsive and little slack.  Remains to be seen how long to get loose since the u-joints are operating at quite sharp angles.
      Seats are pretty nice.  Will be interesting to see how long it will take me to poke a screw driver though them.
      Seat belts are included to hold grand kids in.  Won't go over 5 mph if both aren't buckled.  Yeah, it works to buckle them empty.  Doing this leaves the belt high on back, so you don't have to sit on it.
      Hauling it home, my trailer wheel wells were too close together to clear the tires of the UTV.  This required driving it off center a bit, with one set of tires inside the wells and one side driving over the wheel well.  Creeping over the one well required climbing a 10 inch vertical well.  The ability to lock the front axle differential kept both front wheels pulling as I drove the one side up and over the wheel well.  The guys at Lowes were impressed.  They won't touch any but an unobstructed flat trailer loading.
      tom
