2021 highlifter clutch springs
By quadnut20
By kawasig
Hello there
By TravisCr
A year or so back bought a used 2003 Polaris Sportsman 700 Twin with a plow for keeping the gravel road around the house snow free-
I've used it for the last year and it works well- have a bit of water in the oil I started a separate thread on.
Are there any "gotcha" on using these things with plows?
I took off the small polaris winch and added a Warn 2500, with synthentic rope so I wasn't getting poked by the wire-
Looking for folks thoughts on these.
By middlebrookgt
