I’m having a hard time finding a replacement ujoint for my Polaris. Every parts lookup only shows the entire front shaft, yoke up to the cv joint. I’m assuming these can be replaced like any other universal joint but I’m new to this world… ideas or suggestions? it’s a 1994 Polaris 400L  4x4
Thanks for helping
The old one should have a marking on one side or the other I've seen numbers or letters and combination of both ,Wich teels you the diameter of cup and t ,if you don't have or can't see them measure the specs of without the cups on and the cup itself that should give you the size of,and cross the specs with specs of other u joints online Hope this helps
      Topics covered include:
      Polaris RZR 570 engine repair
      Brake system repair
      Popular related searches:
      Polaris RZR 570 repair manual
      RZR 570 wiring diagram
      Polaris RZR torque specs
      RZR 570 clutch problems
      Polaris 110 EFI engine repair
      Brake system repair
      Polaris ATV torque specs
      AWD and differential repair
      Brake system service
      Sportsman 570 wiring diagram
      Sportsman 1000 wiring diagram
