Hello,
I have a 2022 Honda Rubicon and I have an issue where it won’t start, when I turn the key for power nothing lights up and it won’t start but the lights will turn on with the light switch, I’ve checked all fuses and they’re good, I don’t have a wiring schematic I’m not sure where to start, I checked the ignition fuse when I turn the key on and there’s no voltage there, I used a jumper wire from the batter to the top of the ignition fuse and then it works fine and starts fine but as soon as I turn the quad/key off it won’t start again until I jump the ignition fuse with battery power, just wondering if anyone could give me some tips where to go with this or if anyone has had the same issue, thank you.
Sorry you are having this trouble on one so new, I would suspect your starter cutout relay, not letting power go past the relay, but I haven't worked on one this new, so it could be other safety electronics I don't know about.
    • By realpilot
    • By Cj Winds
    • By OldATVowner
    • By Dsluder
