I am thinking about adding a winch. Should I mount to the front or in tow hitch socket? Are there tow hitch versions for sale. I was wondering about pros and cons
If you're doing a front mount, try not to mount too high as this pulls down and buries you in the goo. If wanting to be able to use front and rear, I would look for removable mount like the small trailer hitches, and a heavy duty cable plug so you can just plug it in front or rear
    • By TomJulio
    • By TomJulio
    • By Olchap
      Thank you,
      Olchap
    • By Tim Keiper
