(SOLVED) Electric issue but can anyone make sense of this? (with video)
Go to solution
Solved by davefrombc,
By rjsummer
By hengstserepair
Nuetral: Runs as expected
Lorne
By Rockbottom
By Mister907
By jeffinotown
