93 Kawasaki bayou 220 carburetor and breather box line diagram
By kawasig
Hello there
By Gtc4d
I recently purchased a raptor 80 for my grandson for christmas. I am trying to make sure it is running properly. i have rebuilt the carb and adjusted the carb idle then the mixture to middle of where it runs rough and it runs great for about a min or 2. then it stalls out. I can usually choke it and it will start so i feel it is lacking fuel. the fuel shutoff valve has been changed and i checked it for good fuel flow. any ideas of what to check next. I am planning to vfy fuel float height tomorrow. I visually checked it by turning carb upside down when i had it apart and it looked level. any ideas are appreciated.
Thanks.
Todd
By digrig
Hey everyone,
By shorty
I removed a winch, mount brackets, relay box from my kawhockey ATV.. also a sturdy steel tube holder for a gas can.. CHEAP to someone who wants them
By Ant-Knee
I recently picked up a '97 Prairie 400 4x4 that didn't run. I didn't get much information from the previous owner except that it was running a couple of weeks ago, then started losing power. After that, it just wouldn't do anything... no crank, no start. The electric start didn't do anything and the pull start seemed locked up. When I got it, it had no fluids whatsoever—no oil, no coolant, nothing. I figured the engine was seized. I took the pull start recoil off and tried turning it with a wrench but it didn't move. I took out the spark plug and put some lubricant in the spark plug hole. After a while, I was able to get it moving and it turns now but isn't super easy to turn. I put oil and coolant hoping it would fire up but still nothing. I took out the starter and tested it and it worked perfectly. I tested the starter solenoid and it clicked so I assumed it is working. The battery is good and holding a charge. I also put in a new spark plug as the old one was somewhat corroded but didn't look that bad. After I tested the starter, I put it back in and ran some power directly to the starter. It started cranking the first time I gave it power but didn't do anything after that one time.
Any ideas of what I should do next would be greatly appreciated. Always wanted a quad so I really want to make this work but not sure if it is do=able.
