Lakota 300 / Bayou 300 crankcase breather tube
By middlebrookgt
By Gwbarm
I have had my new tires for a while, chronic procrastinator, decided it was time to get them mounted up. Against my better judgement i decided to mount them myself.
I got one of these Harbour Freight manual tire mounting machines, mounted it to a half pallet to make it more portable. Very impressed with the quality and amount of tools that came in the kit for a low price point.
The bead breaker worked very well, i wasnt sure it would be able to do it, i think these tires are original to the bike its a 2004, but with enough lube, mothers concentrated car wash straight, it finally broke the bead.
Tire fit very well on the machine and it tightened down good.
The extra long pry bar that came with the kit worked well to get the outer rim of tire off.
Half way there, half way there no issues, then it got serious.
I pulled and i tugged had 3 prybars working this thing and it wouldnt budge no matter what i tried it would not come off, until i got the grinder out and cut it off. Im sure most of you see what the problem was. I didnt notice it until i was too far in to change direction. On this particular rim the tire goes on and off from the back side of the rim, not the front like what i was used to. The back side is the low side. Plus to add to the problem tires were old and not very strechy, i have a greater respect for how well these ATV tires are made with well reinforced sidewalls, even with the grinder it took me a minute or two to cut through it, of couse i was being very careful not to nick the rim. Anyway the HF machine worked well and the tire is off, hopefully the next one wont be this bad. Lot of hard work for an old man, glad i can still do it.
Now for the fun part , cleaning up the old rim, years of stop leak and slime caked on the inside, that stuff dries hard, the little Milwaukee is good for getting into tight spaces, but wasnt quite up to the task.
Needed a few more RPMs.
Old rattlecan paint just flaked right off. Now time to decide on a new color, tired of the boring gray. More to come!
By geekmonster
I need a service manual for a 2001 lakota sport im having issues with my oil pump getting jammed
By exalrod
Hello All !
Could anyone help with this?
By Gwbarm
