Stuck
well today i wanted to go muddin so i noticed a mushy spot in our yard. i went through it and the first thing i did was sink like 4 inches down into mud!:aargh:so i tryed to put it in reverse and push as i ease the gas and i sunk another inch or two:aargh::aargh::aargh: so now the thing is sitting there and i cant ride:aargh::aargh:
Winch it to a tree?
Tow strap to a car?
Get an extension cord and your mom's hair dryer
and dry up the bog?????? :rolleyes::yes:
I told you....I'm off my meds!
*hic*
-TD
    • By Brantley11
      Hey everybody,
      Here is where we sit:
      New 93 Non Ethanol Gas
      New Spark Plug
      Bluish white spark
      Good Compression
      Here are the readings:
    • By mga
      Hello there
    • By Params_sweden
      Hi!
      I got my KLF300 running again with your help a couple of months ago, at that time it was the ignition coil that had failed. It has been in use since then without issues until two weeks ago.
      When the new issue showed I was going at about 10km/h and it suddenly slowed to a halt. I started it again after that with choke and I drove it 400 meters and parked. Next time it was really hard to start, and since it was low on gas I thought that was the problem. It didn't get any better with a full tank, so I assumed it was the cold weather, and adjusted the pilot slightly.
      After that it I actually got it started again with full choke and some slight gas, I drove about 300 meters and then it slowed down to a halt again. After that, it hasn't started again.
      The compression is 165psi. The spark has good intensity, the ATV has functioned before with the same spark "intensity"/light. I *assume* that it has gas as well, there is definitely gas on the spark plug when I remove it
      I have checked the carburetor slightly, the float works, diaphragm looks ok, but I haven't disassembled it to really look for dust and such in all the small places.
      My theory right now is that it might've been some dust in the gas tank that went into the system, it's just a theory
      I'm thankful for all the help and pointers I can get, don't hesitate
      / Pär, Sweden
