YAMAHA Ultramatic - Infinitely rotating bolt
By BruceG
By Louznmemind
By Admin
By DarkRider
By adr94
Hello,
I was able to repair most of the little problems on my 2006 BRUIN. I still have little things to do...
I changed the Hazard light Switch because it was not locking when pushed and now it is not working at all. When I connect it (not sure of the wiring -4 wires but a lot of connection possible on this HELLA 3916-01 switch-) the flashing lights button (on the handlebar) is acting like the Hazard light switch.
