I cant seem to find what this part is called. Can anyone point me in the right direction? I must be misinterpereting the parts catalog or something? I dont see it in the rear axle section. I think it may be in the rear brake assembly section? click link to view picture.
[removed broken image]
I have looked at the parts manual. Unless I'm missing something (I hope I am, and someone points the part out that is right infront of my face). I just need the aluminum part that appears to house the axle/brake for the rear end. The chain doesn't keep enough tension the way it is right now. I found this quad at the dump and got it running, just need to replace whats broken in the picture.
Are you sure you are adjusting the chain the right way ?
I think that bike has a pinch bolt and a rotatable axle housing. You undo the pinch bolt and then rotate the rear housing which is eccentric with the axle... I think. Unless the axle housing is worn out it shouldn't prevent chain adjustment.
--------If you can see the picture now, then you might see what i'm talking about. Thats exactly what I thought it would be called. The axle housing, the aluminum part that encases the rear axle, has a crack that goes all the way around it right near the sprocket.. But when i've searched through the parts catalog, or online, I don't seem to find anything??
On 5/17/2024 at 10:39 AM, Gwbarm said:
Still cant see your photo
Check if you can see the photo now?? Idk what the deal is with my photos not working on here. I tried posting these ones with a different method this time.
here is the parts diagram where I think I see it visually in the image... but when i scroll down the list I dont see axle housing? idk...
here is the link to where i was looking at the diagram.
https://alpha-sports.com/eton2_parts.htm?fpg=/eton/2005Yukon(YXL-150)/25.htm
I can see the photos now and from what i can tell from the parts diagram it is part #1800388 Rear wheel axel bearing seat. Click on it and says part is no longer available. That may be a hard find, but i would look on ebay. You might also do an internet search with the part number and find a new old stock one floating around.
    • By noticon75
    • By Elk
      2002 Polaris Magnum 325
    • By HHurks
      Thank you!
    • By toe420
