Anti friction is good, but I'm dubious about their claims it repairs wear.  I mean, if it builds up a hard layer on metal, how does it know the difference between crank shaft and bearing journal, and if it builds up the surface, by how much, and does it cater for the different clearances required between roller and shell bearings. If it only puts on a layer one nano-particals thck, then that's not going to effect several thou of wear, and if it keeps building up thicker and thicker, then how does it know to stop building up for the required clearances things need to allow for expansion and oil flow.
Truth is it's probably no better than any of the other friction reducing compounds we use..  nano or not.
Interesting stuff it claims its smart nano technology and only sticks to bearing surfaces, but then it shows a photo of how it repaired scratched piston rings.
Variations of zinc have been used as friction reducers for a long long time. That does work.
Quad bikes have a lot of roller and ball bearings though, and those don't wear from friction, they just work and flex the surface until it starts lifting off. A friction reducer in the oil of a quad would help piston scuff and gear wear, and a few bronze bushes, but you wouldn't want to get it on a wet clutch.. It wouldn't be good if you had a catalytic converter on your bike either..  Or perhaps, an O2 sensor.. not sure about that though but they are generally pretty sensitive.
    • By noticon75
    • By oztrax
      MAX 4 6X6 2008
    • By bradleyheathhays
      Unfortunately it looks like I have some people in my new neighborhood paying a little too much attention to my auto and for the first time I'm feeling a need to add some security system(s) to old yeller.  I think just a basic remote arm system would do, not interested at all in remote start or unlock.  I'm not familiar with modern alarm systems, but here's what I 'think' I need...
      - Door switches for all 5 doors (rear hatch).  Probably a PITA to install but that's only an initial idea.
      - 'Bump' alarm (not sure what it would be called) for if a window breaks or if something is jarred
      - Geo-location function like a low track or something similar
      Additionally I'd like to install possibly 2 start kill switches.  I'm not sure where inline these are normally installed but my impression is that directly in line with the key ignition switch would be common.  But then what if someone jumps the starter with a screwdriver...would this type of switch work in that instance?  So that leads me to the idea of a second ignition kill switch which would either be wired between the battery and starter motor, or between the starter motor and ground.
      And last...security lugs.
      So am I over thinking this here?  What's your recommendation for what I really need and maybe a good but economic alarm system that can get this done?
    • By toe420
