2000 Suzuki will not fire. Fresh fuel, new plug, has 170 pounds of compression, super hot blue spark, won't even fire if you put fuel directly into the spark plug hole. Carburetor has been cleaned. Any ideas? Thank you...
And this is not even firing right ? No backfiring or anything..
Well a plug can fire just fine out of the engine, but then not fire once there is compression, so I'd try a second new plug. Sometimes, just very rarely, we get a dud plug, but also, if a plug gets stale fuel on it, it can get fouled in just a few cranks and near starts.
Yes it has been running fine, shut it off one day, and would not start the next day.  If you read my first post I have super good spark, hot blue spark that will jump 3/4 of an inch so I believe my coil and key switch to be ok and my kill switch must also be ok.  Putting fuel directly into the cylinder it won't do anything, won't even backfire.  Even tried another new plug.  I appreciate everyone's help.
Low enough compression, or the ignition timing being far enough out can let them ignite the fuel without a sound or kick, and burn the plug almost dry, but not start. Try starting it and then pull the plug and check if it's wet, or perhaps, only wet on the metal part, or really completely dry..
    • By DrtyGrlKristin
    • By hengstserepair
      Nuetral: Runs as expected
      Lorne
    • By Mister907
