Just now, darklord19991 said:
We rebuilt the engine put wiring back together it ran before but now it won’t and has a weak spark we have been trying to figure it out for about a week and still nothing changes does anyone have any help on what it might be?
On a bayou 220
Have you tried a new spark plug ?
Do you have a good battery ?
What colour is the spark, blue/white, or yellow?
Will the spark jump 6mm, 1/4" ?
And most importantly... What have you done/tried so far ?
Well you should get the service manual and follow the diagnostic process in there to figure out what's wrong. That ignition system on that bike may not be cdi. Some have an ignition unit like a cdi, and some books even name it as cdi, but it doesn't work as a cdi does. That system needs an unusual (for these days), coil.
But are you sure that it is a lack of spark causing this problem ? A one mm spark might be enough to start an engine, it often is.
    • By RGS
    • By Kawasakibayounospark
