2000 Big Bear 4x4 400.
do the front and rear drive shafts have to be lubricated? they have boots on them and i was wondering if i had to pull the boots off and grease the "U" joints? These are the ones close to the engine front and rear.
    • By buriedpast
    • By hengstserepair
      Nuetral: Runs as expected
      Lorne
    • By Mister907
    • By en4cer
      Problem number 1,
      Problem number 2.
      Any help would be nice.
