Well if the dash is all behaving normally, you should recheck the fuel pump is running, and has good pressure. If you turn the key on the pump should run for a few seconds I think. After taking the fuel lines off it's recommended to turn the key on and off several times to bleed the air out. And if you can get a hand onto a rubber fuel hose, it should stiffen when the key is turned on and he pump applies pressure. The hose has about 50Lb pressure if that gives you some idea.
    • By realpilot
    • By jay41198
    • By mehim
    • By OldATVowner
    • By LMI
