I have a 2009 Honda rancher that has fuel coming out of the injector but will not crank. I can spray gas in through the breather and it will run a few seconds. Any help appreciated
Sounds like you may be getting to much fuel or to little fuel through the injector, is the plug wet. I would check fuel pump pressure also. Its also possible you have an air leak  causing to lean a mixture.
A friend of mine rigged up an injector testor.  He wanted to  visually see that the injector delivered fuel and the quality ofg the atomization.
The other thing he checked with his "injector testor"   ..This guy was from Romania and a natural mechanic....he wanted to see if the injector Leaked fuel!
    • By Cj Winds
    • By cruteg8
      Does anyone know  the orientation of the bell crank for scrambler 400 2x4 it was not hooked up when I bought quad the way  i put it high goes into reverse and vise versa I flipped it 180 but that put  the shift rod at big angle and it just kinda grinds into gears so dnt think that is right either pretty sure it has to be the exact orientation and the rod adjusted accordingly but I cant seem to find it anyone knows please help
    • By 88classic
      I have (2) sets of brand new plastics available for Honda Rancher 420 2014-2023. These are genuine genuine OEM Honda plastics. One set is white and the other set is green. The boxes these are in are too big to ship.(Unless you want to pay for it. If so, lookup your own shipping rates from 17325 and box size is 58"x35"x18").  $400
