Regarding a 1988 Moto 4 200. I see there is a brake switch behind the left brake lever on handlebars, but only a single filament bulb in the taillight. Do these have brake lights or just taillight?
Edited by killerklown
  • killerklown changed the title to YFM200 Moto 4 Taillight Bulb Question
I see there is a service  manual  listed in the downloads section.  I downloaded the manual.. It  is for a 1986  model  but likely the same for the '88...  There is NO brake light.  That switch on the brake  handle  is a safety  cut out switch  so you cannot start the motor without  the brake being on  rather than  a brake light switch.
Edited by davefrombc
    • By vaneleus
    • By Adamb2025
    • By Olchap
      Thank you,
      Olchap
    • By Louznmemind
      I know this is a stupid question but here I am.. I'm wanting to have the ability to disable my taillight/brake light on my '96 Polaris Xpress at will, it comes on with the key and there are times I don't want it to illuminate. I have basic wiring knowledge and I'd like to put a toggle switch to disable it. I'm not sure of the wiring setup on this thing, can I just use a toggle switch on the ground wire to kill it when I choose? Can someone clarify which wire I need to work with and the easiest way? Excuse my ignorance yall.
