I’m having a issue with my choke when its on it runs fine when I cut the choke off the atv cuts off went to take the carburetor off and saw the choke plunger broke at the nut to screw it in could this be my issue? Do I just need to buy a plunger kit and put it on? I took the carburetor off and cleaned both jets anyway just to make sure and it’s still having issues staying on
That could definately be your problem, i would fix that so its working the way it should and see if thats it, if not them go from there. When you pull the choke off it may be going too far leaning it out so much it dies. I have seen this before with partially clogged jets but you cleaned those so i would fix the choke .
    • By Joeguy
    • By Dsluder
    • By Jdeaton011989
    • By gordonmacritchie
      all fuses are fine
      Hello there
