anybody have a electrical drawing
cant figure out problem
new starter relay, when i turn the key on all 3 leads to relay are hot red, blue, blue white. Is that correct. nothing happens ir clicks at the starter relay when i push the start button
on the relay closest to the cdi and nearest the brake light the relay vibrates as if it is opening and closing rapidly
the batter is new and good
if i short the B and M lugs on the starter relay the engines turns over but does not start and there is no spark
I ordered a new cdi but the one on the machine is only a few months old but a aftermarket
anybody have a electrical drawing or advice ir know what that relay symptom is and what activates it
Im a new member so i cant download the manual until i have 10 posts
i wonder ig this counts as number 2 post
anyway i cant tell much about the drawing without the page that identifies the component  by the location number on the drawing
can you tell what the relay beside the cdi on the closest to the taillight
there are 5 relays
3 on one side and 2 on one side
its the one closest to the cdi
I have checked the ground and the battery is good
the red light on the console flickers like the relay does
Should the red, blue , and blue white wire to the starter relay all have 12 volts
Another question
the oem stator has 3 white wires going to a round connector under the seat
the after market stator has 3 wires to the connector but the are all different color wires
Does it make any difference how they connect to the white wires that are part of the wire harness
Only when engaged. If the relay is clicking, it's engaging with the switch. Did you test the starter solenoid, starter? Jump the starter? Forgot to add the descriptions page from the manual for you (see attached). Should be Blue/Black, Blue/White, Red wires to the relay. My guess is you have a bad starter/solenoid.
Maybe check out this video for some guidance:
2007-2012_Yamaha_Yfm400_Big_Bear_400_4x4_SM Descriptions.pdf
If i jump the starter across the B and M posts on the starter relay the engine turns over
Im gonna look at the electrical info
i also need to confirm if the blue and blue white wire only have 12 volts with the key turned
Im still curious of the clicking relay beside the cdi
Ill test the starter relay along with a new one
and the power from the start button
If the neutral light is on would it matter if the button on the left brake is disconnected
it was broken and the wires are disconnected
oh well
UPDATE
tested and replaces the starter relay with a new relay.
no change, nothing works
i disconnected the aftermarket cdi and connected the old oem cdi,
the oem cfi had failed and would not produce power to the coil for spark which is why i replaced it
with the oem cdi when i hit the start button everything seems to work and the engine turns over, the relay near the cdi stops the rapid connect/ disconnect but there is no spark which i expected
im getting the cdi i ordered tomorrow so i will then see if it will have spark and start
    • By DrtyGrlKristin
    • By Mister907
