The neutral light burned out and I can't find a replacement. Bought one off Ebay last year but it wasn't right one. Guy never responded when I told it was wrong.
I know it is in neutral because I can push it around. Can't do that when in gear.
I guess I'll have to get a neutral switch and start tearing brackets off to get to it.
Thanks for your response.
The light has to be on to complete the circuit even if its in neutral, you sure its the bulb, the switch is fairly easy to change on the 350 and fairly cheap, to answer your question the starter cutout relay is close to the soloenoid in the wiring harness as i recall its not easy to find on the 97 but its a small black box that plugs into the wiring harness.
My light has been out for years but it always cranked if it was in neutral.
I did find a little black box in wiring harness but I believe it only has two wires going to it. I'll double check that.
I checked the bulb with an ohmmeter and it checked as open compared to the reverse bulb.
Somebody added modified floorboards to this one which hides the neutral switch.
Thanks again for your asvice
On some of those older Yamaha's I found those relays located under the back fender, near the taillight.
Really not the greatest place to get access to but worth checking out if you're still looking.
Sorry I have not been on here for a while. Started having problems with my truck. Just put an exhaust on it. I have Drs appointments this week. Will get back on it by the weekend. Does anybody know where I can get a bulb?
https://www.yamahapartshouse.com/oemparts/p/yamaha/123-83516-21-00/-bulb-12v-3-4w I think this is it, maybe verify with the diagram in case i was looking at the wrong model.
    • By hengstserepair
      Nuetral: Runs as expected
      Lorne
    • By Mister907
    • By jeffinotown
