Background,
Any Ideas?
First, the battery is probably bad which is why the starter solenoid was buzzing. Charge it and take it to a auto parts store for a load test (usually free to do)
Next I would check the negative cable from the battery to where it is attached to the frame, you probably have a bad ground point. Corrosion probably.
Next check the fuses, may have some corrosion there. Beyond that you will need a meter and schematic, but since you indicated not being good with electrical problems, not sure if that will help.
    • By realpilot
    • By OldATVowner
    • By kevinohio
