Well, I think not even 5 mins after I posted that, I got it running. I never use the “kill switch” on the machine. I always turn all my machine off using the key to avoid draining the battery if I did forget. So guess what the problem was? That’s right, the kill switch was in the off position. Ugh, I feel so dumb. Lol.
Im jumping on this post as I cant seem to find how to start a new post
i have a 2008 big bear 400
was running, now will not start
i have voltage coming from relay to starter
the wires from the relay have voltage with the key on, it is in neutral
i have good ground on the frame from the battery, i added another ground from the wire harness to the frame close to the battery ground
when i hit the start button the relay engages ,  power to starter but nothing but a click when i hit the start button
Any ideas on what to check
i have the electrical drawing and the
Blue whit wire to the cdi has voltage with key on
How do you start a new post
    • By realpilot
    • By OldATVowner
    • By HoldenBoy
