Thanks for the reply. I do have a service manual. It is probably due to my age, but I am having a hard time with the procedure it is listing. Although co-pilot says basically the same thing. I'm going to try to remove it today. Hopefully I will be back on here with what I find.
In case anyone sees my post, I will give a follow up. Removing the transmission drive shaft is quite simple. Since I already had the gears out of the transmission it only took a few minutes. First, I removed the clutch cover, second, I removed the driven clutch off the shaft, third I removed the bearing retainer on the inside of the transmission, and finally the shaft just tapped out.
    • By hengstserepair
      Nuetral: Runs as expected
      Lorne
    • By tepin
    • By Brent Wright
    • By sandman001
      any ideas how to correct
