You have to take the throttle plate off the shaft two small screws dont loose them, then the shaft comes out and you can get to the spring, there are a few other small pieces in there dont drop them they are small and easy to loose also.
    • By LashinWheeler
      Any help would be great,
      Thanks!
    • By cruteg8
    • By flyinbrian365
      What's Covered:
      Topics covered include:
      Polaris RZR 570 engine repair
      Brake system repair
      Popular related searches:
      Polaris RZR 570 repair manual
      RZR 570 wiring diagram
      Polaris RZR torque specs
      RZR 570 clutch problems
      Polaris 110 EFI engine repair
      Brake system repair
      Polaris ATV torque specs
