Hi all,
Good Morning!
Has anyone had a problem with the small aluminum 90 degree elbow popping out of the valve cover and blowing oil all over the place? It looks like it is simply pressed in and will most certainly repeat the offense. Any experience you all can share with this issue?
Thanks in advance.
Having problems with the battery draining while riding. It has a new battery, it does have eps, a lightbar and a winch. Can ride it for an hour or more just fine, but eventually the battery runs down to the point it can't keep up with fuel injection and it'll sputter, limp, and die. It also throws codes for the throttle position sensor. I'm not sure if that is related or not. Any ideas?
I have this control on my Big Bear I have not seen one before, it appears to have a cable that goes to the front differential. Im assuming it's either a differential lock or to disconnect four wheel drive, does anyone know what this is or how it works.
