Engine Type 449cc, 4-Stroke, 1-Cylinder
Bore and Stroke (mm) 96 X 62
Compression Ratio 11.8 : 1
Cooling Liquid
Ignition CDI
Transmission 5 Speed with Manual Clutch W/ Reverse
Final Drive Chain
Starting System Electric
Fuel Delivery Mikuni Carburetor / 42mm
Front Suspension Independent Double A-Arm
Rear Suspension Linkage Type
Front Brake Dual Disc
Rear Brake Disc
Front Tire 22 x 7-10
Rear Tire 20 x 10-9
Dimensions (L x W x H) 72" X 46" X 45"
Seat Height 34.8"
Wheelbase 49"
Fuel Capacity 2.9 Gal.
Dry Weight 378 lbs
Colors Black, Red
* Powerful 449cc, single cylinder, liquid cooled, DOHC, 4 valve engine produces 51HP at 7,500 rpm.
* Lightweight and durable 35mm intake and 28mm exhaust valves provide precise valve control at high rpm.
* Ultra-compact, lightweight, high-tensile steel frame designed for low vibration, optimum rigidity and maximum durability.
* Compact and durable five speed transmission with reverse deliver all that power to the rear tires with maximum efficiency.
* Powerful four valve engine and 378-pounds dry weight give the MTX-450R a leading power-to-weight ratio.
* Reliable, pushbutton electric start in any gear adds extra convenience.
* Double A-Arm Front Suspension with adjustable gas reservoir shocks deliver superb travel and precise handling.
* Rear suspension system is linkage-type, controlled by an adjustable shock with 9.4 inches of travel.
* Lightweight front and rear master cylinders, combined with twin powerful front discs with twin-piston calipers and single rear disc, deliver incredible stopping power with progressive control and feel.
* Multi-function LCD display.
* Cool LED taillight ensure the MTX-450R is highly visible from behind.
* EPA & CARB certified.
    • By cavry
      Cavry
    • By jay41198
    • By logray
    • By OldATVowner
    • By Shorty51
